Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
Thread: Dialing in my IMIG 200... Question?
    Always check a new spool of wire for cracks in the plastic (where the sides connect to the hub) or warping. If it's split or warped, the wire can get pinched in the side as it's pulled off causing poor feeding.
    Both sides of the spool need to be straight. Use only enough tension on the spool to prevent backlash at full wire speed.
    PP 256 (SOLD) : 2013 250EX : I-MIG 250P/w 20' Profax gun : Power Plasma 60/w p80 torch : Hobart Handler 135/w 12' .023" Profax gun : 3M Speedglas 9100XX
    I'm not an expert or an Everlast employee, I'm just a hobby welder sharing my experience and helping where I can.
    20 lpm or 20 cfh since the flow meter is in lpm measurement
    small rolls of wire dont feed good . i like my 205 since it will hold a 44 pound roll of wire
    20cfm... I use Smith flow meters on the Mig and Tig.
    dont like my flow meter since all my others are meters are cfh
Size:  4.0 KB Low cost backpurge Click image for larger version.
    haha, that's a good idea!
